Morning guys, i have a Hypertherm 65 sync that will not fire anymore when in manual mode or anything. can anyone tell me what voltage I should have coming out of the (torch on/off) outlet on the langmuir control box? The red light inside comes on when i click (torch fire) but nothing is happening!
hypertherm is on and air is supplied
no fault codes on anything (langmuir or hypertherm)
all other plugs are ran correctly to the VIM
ground is on work piece on table
fire control version 21.1.5 is up to date
*** this happened after trying to run a sample test for the very first time, i hit start, torch came down to touch off, came back up, then nothing other than an error code stating (toch did not fire or sense any voltage)
any help would be great so i can try and get this bad boy running!
morning Phillipw, those pictures were taken as i was walking out of my shop for the night so everything was shut down and cleaned up. air was applied during the trial. I do appreciate the input though!
i just tested the torch manually and it fired by jumping the connector on the back of the hypertherm unit so something on the fire control / langmuir side isnt working
So I just got my table hooked up to the 82i and tried to manually fire for the very first time and nothing. I jumped the plug and machine fires. Tested continuity on the pins on a control box when commanding to manually fire and no continuity. I took the control box panel off and all my lights are on including the red one above the surface mount relay on the motion control board. I called Cameron this morning and he’s sending me out a new motion control board. The relay is no longer replaceable, because it’s surface mounted soldered to the board.
