Skipping Gcode lines
I need help figuring out how to jump to a certian line of Gcode any tutorial video or anyone willing to DM their number to walk me through on cut control I’m on V23.1.1
All you need to do is highlight the specific line in the G code viewer and select ‘run from line’. It should highlight that particular line in the graphics viewer.
I will say that I’ve never found this feature that useful (not on CutControl, on other CNC controls). It’s easy to skip past important lines that set mode and then end up with unexpected results. If you just want one op I find it quicker to just re-post that file from Fusion 360 with the ops that you don’t want marked as “supressed”.
Our parser does a pretty good job at preserving any required setup and modal codes for starting mid program. That being said, caution and a finger on the space bar should be used any time a program is started in the middle just to be safe!
I’ll press generate and then continue and it just keeps cycling the continue button pop up back to back it wont actually run the machine after hitting continue.
