Setting cut height on pro with 45 Sync
Hi all, recently went to the 45 Sync. and trying to get the cut height set. It calls for .14 for my 14 Ga. so I made a straight line sketch with a .14 height and cut it pausing mid cut and it measured .165 so I re did the cam and changed the cut height to .115. both in the tool editor and in the fusion post processor, cut and paused again and still at .165 actual. I checked both G codes and they call for what I have reported here and my torch is not at the limit of travel and the sheet is flat on the table so I don’t think the spring back comes into play here. using the smart voltage. Any Ideas ?? BTW the cuts and dross seems perfect right where it is but I’m concerned what I might get on thicker stuff. EDIT: using F-360
Your cut speed may be to slow, bump it up some.
Sorry I misread the post.
Don’t think cut speed applies here.
Put in 0 for his spring back, or even -.02 and see if that gets it.
I’m at 220 ipm
