Scaling in fusion 360
Need some tips on sizing images when getting worked on in fusion 360 , every time I size it it’s never the same in fire control and I always have to play with scaling in there ,
Is there a way to set it to the correct dimensions you need it and it be ready to cut in fire control ?
I gave an answer on your other post. As I mentioned, not sure if this helps.
@Freddie1
By how much is it out of scale? Is it only slightly out of scale or is it 2 and 1/2 times at a scale?
Could maybe you have set an incorrect kerf width that’s reducing the size.
Or maybe you have an offset selected.
Can you post the f3d file that created the NC file that is the wrong size?
