looks good!!
i forgot to mention the mounting holes were 1" off from the rail mounting bolt spacing. i forgot i burned an inch when measuring…
looks good!!
Ha! Is that where you intended it to go?
With where I’ve got your mount at, it’s at the perfect working height for me while sitting on a high top bar stool in the shop.
i put it on the other side after initially mounting it on the outside, this lets me swing it over the table when not in use. i will eventually have this on casters and will have to park it about 3’ or less from my lathe so i can still use that side of my 2 car garage. the left side with the electronics will be pushed up against a cabinet.
i will try and get some pictures of mine assembled and poorly painted tonight.
Might want to put that on the outside so as to not interfere with loading material, but it looks great!
I load from the back if its a full width piece. i will probably move it to the end of the rails right now i only have around 100° of swing.
