When I start Mach, Red reset button blinking.
I hit the red reset button — the stepper motors go off and running.
But I am at the limit of the travel so I hit the stop button.
It stops the pulses to the steppers.
Then I hit the reset button and I get status: RnR motion card not found.
Exit and reload Mach software and the process repeats.
When I hit the up down left right arrows. Nothing happens. The motors don’t respond
and the display counts do not increment/decrement.
If the displays are not at 0.00 0.00, and if I select “go to zero”
It attempts to go to zero
For grins I loaded the parallel port instead of the RNR and in that mode the
displays for x/y increment and decrement (and of course nothing moves on the crossfire)
when I push the L/R U/D arrows.
Very strange as some commands seem to be going through
I just keep getting the “RnR motion card not found” or something like that.
I can enter x and y values into the display and then tell it to go to zero and it will do so.
It will do that regardless if motors are plugged in— I see the red LED flash
If motors are plugged in, it moves to 0,0 if not then the displays countdown to 0,0
Pushing any of the jog functions does not have any effect regardless
if I were to disconnect the x and y motors
Let me clarify, when I first turn things on and hit the reset, it doesn’t drive the motors to the stops, it drives them down to 0,0-
It just happened to be near the stops when I started the process. I manually rotated the lead screws to put the carriages to center of travel, now it just goes to 0,0. Then after that it says the card is not found
I am also having the same issue with my machine. It says RnR motion controller not found, when I plug into my computer it says “the last USB you plugged into the computer malfunctioned and windows does not recognize it.”
Can you pull the cover off your electronics box (make sure to have mains power unplugged but keep USB plugged in) and see if you have an LED lit up on the USB motion control board?
I’m having the exact same problem. I’m getting an error that says RNR motion card not found and windows says it’s not recognized. I unplugged the machine, pulled off the cover, and plugged it into a powered on laptop and there are no LEDs anywhere in the box. Does this mean my motion controller is bad as well?
Hi, just assembled my crossfire table after waiting almost 6 months for it over here in Sweden, got everything working but after the first try “for real” with the plasma cutter connected everything died and i can’t connect again get the exact same error as above with the windows not recognising USB device and a black card in the cabinet. Is the RNR card smoked ?? So dissapointed
