Replacing slats with SS
Is it wise to replace the steel slats with Stainless Steel? I’m sick of the rust and corrosion.
Thanks
I guess you could do it. If you use a plasma cutter conditioner, they last until they no longer exists. I use Sterling Cool. A 5-gallon pail will last months. Plus, the replacement slats are under $50 delivered from Langmuir. My only issue is that the pro table takes 12 or 13 slats, and there are 10 in the box.
Thanks, I haven’t heard of the Sterling Cool. Wow I just went to their site. It’s a no brainer.It’s exactly what I need. Thanks again
Just remember you need two sets. Hopefully the slates on the end are good. I keep the extra set on hand.
I’ve got 5 gals on the way! I didn’t know they made a product like that. I let my cutter sit for a few months and I couldn’t believe all the sludge and corrosion. What a mess. Took hours to clean. And I have oversized drains. This will make it tolerable. At work we rent our office from a Steel Fabricator so I have access to a lot of scrap metal. If you’re interested I just launch my new website. dannysworkshop.com. Thanks again!
Nice woodworking. I mix a quart or do with the water. It lasts longer than expected.
That stuff works great. Thanks again for the advice. Langmuir should list that as a must have. And they ship fast. Ordered it on Sunday, receive it on Wednesday.
Cutting Stainless steel will put chromium into your water, and it will turn into a paste if you don’t keep up with it. Now, if you need to cut Stainless, that’s one thing, but to have the slats deteriorating your water. Just my two cents. Not to mention the replacement slats are around $35, from Langmuir
