Not a big deal it has only done it twice, my torch will fire and start a cut then FC will stop and tell me the pierce delay is too short and the torch did not fire (when it actually did fire) and sit there with the torch on showing the voltage in THC…anyone else having this happen?
I am having the same problem. Did you resolve the issue?
I increase the delay point 01 and it hasn’t happened again
I am having the same problem every single cut now.
You mean you increased the pierce delay with 0.1 second?
What plasma cutter are you guys using?
The razorweld yes i had set it too .4 for 16g raised it too .5 hasnt done it again
May have been set to .3 but it was odd.it fired cut for awhile then stopped with the torch on saying it didnt fire, was showing voltage in thc
