Razorweld air check won't shut off
Has anyone with a razorweld 45 ever had the air check mode of the cutter not shut off right when you turn on the machine. When I was turning on the pro for the first time it fired the torch once without me doing anything and wouldn’t stop blowing air. The relay inside of the control box is clicking if I set Firecontrol to fire torch manually.
Figured it would out. The machine torch was wired incorrectly. Took it apart and the trigger wires were wired together.
How did you wire your machine torch? Struggling to get mine to fire.
Call or contact the seller.
