I have the Razorweld 45 with X45 torch… What speed IPM. Do you guys use for 1/4 steel. And how do you cure that bevel on cuts…
nice clean cut…but that does not look like a speed issue…
if the left side of your picture is the bottom with dross then your torch is too high…
Torch height may be to high. Consumables may be bad. This is common with a hand torch getting it adjusted completely straight is hard.
Look at my post … I think get torch straight in holder first… Then maybe slow to 35 IPM to see what happens just cut a short line… To see what happens… Would do on mine but I have double gantry… Trying to see if its your single gantry… Mechanic416 doesnt know we bored out holder… And made torch straight… Our secret !!! I will look at mine too…
I did some nice cuts on 1/4 but ran 20 ipm
