He states the Hypertherm 30XP consumables fit the X45 torch. I did not know this but I found out Hypertherm sells fine cut nozzles for the 30XP. If you try using Hypertherm consumables I would recommend using the Hypertherm swirl ring also.
Yep to confirm the powermax 30xp finecut nozzles fit the x45 torch. Just make sure you also have the fine cut deflector shield along with the fine cut nozzles. They will not fit inside the original shield that comes with the x45. I’ll upload a picture in a few hours to show what that looks like.
The only thing I’m unsure about is wether or not they are best run at 30 amps or 45 amps. I haven’t tested them yet as I only recently received them
Probably would be better to have fine cut consumables designed for 45 amps but I don’t think there are any available
