Anyone ever had this issue, I have no air nor fire coming from the torch. Within fire control I am using the “test” function which tells me to press the button to fire and then press the arc on button once I see an arc, however I never press it because I do not see any arc.
I have the crossfire pro, thc, with a razorcut45 with cnc ports and handle torch, not machine torch.
I have air hooked to it and powered on, 2t is selected and the corrects lights are lit up on the plas machine itself.
I am not receiving any errors from fircontrol during this process. I also ran a break in process which runs the machine from one corner to the other and the movements seen to work correctly.
I removed the handle torch from the z-axis bracket and tried it manually with no difference. I then removed the cnc 50:1 divider cable from the machine and tried to fire manually and no fire still. Removed the on/off cable from the port on the plas machine and ran manually and still no fire.
If I remove the power cord and my air line from the razorcut45 and hook them to a different plas machine (hypertherm 45), that plas works fine with no issue.
The razorcut45 should at least shoot air out once the trigger is pulled right? It’s as if the trigger or lead is just dead to the system.
I currently have a cable from razorcut45
CNC torch on/off port to the langmuir system electronics box torch on/off port.
Currently have a cable from razorcut45
CNC 50:1 voltage divider port to the DIV port on the THC electrical box.
Currently have a cable from the DIV OUTPUT port on the THC electrical box to the langmuir system electronics box THC Port.
The ground lead is plugged in the ground port on the razorcut45 and the torch lead is plugged into the torch connection on the razorcut45.
This is correct right? Or do I have something backwards?
I am getting roughly 70 psi showing o. The razorcut45 gauge at the front of the machine. And no errors on the lights of the machine.
Anyone have any ideas? I already messaged razor weld, I just got this plas delivered on friday and hooked it up not even a day later and no fire.
