Hello, I am at the Z axis alignment step in my new build. It seems that with initial shims installed per the Langmuir build instruction worksheet, the touch off pattern looks like a smiley face with the “forward half” of the circle presenting first. If I change shims to improve touch off pattern towards a full circle, The 3-2-1 block touch indicator results get worse. Is the first touch pattern supposed to be a full circle if optimally aligned?
Anything prior to machining the plate really doesn’t mean much. You’re going to readjust after surfacing, so just follow the steps, and you’ll get there.
Thanks Micro!
