Please advise, I’m new and still learning. Thank you
Check and tighten the couplers. looks like they are slipping and why your design is off center. Also make sure your cutter is set to 2T and not 4T on the front. it’s not turning off when moving to the next cut as indicated by the lines between cuts.
Thank you I will look into this ! There is a lot to learn, lol
