Hey y’all, I have had my CF Pro table and cut60 set up for a month now. I was having non stop issues with dross, bevel and junk cut quality. I checked EVERYTHING and nothing helped till I stumbled upon the torch o ring. Back story, with the junk cut quality I decided to upgrade to the x45 machine torch. That didn’t help so I went to put the hand torch back on for more testing and found the o ring was jammed in the torch lead tube! So the hand torch had a major blockage, and the machine torch had a massive leak! After seating the o ring, my cut quality is perfect! Just one more thing to check if you are having issues!!
I have seen this a few times on other plasma cutters as well… If you do not seat the torch all the way in the air pushes the oring out of its seat.
Mine was completely seated, and it did it twice!!
I wonder if the copper tube is a bit short?
Can you add a picture of the o-ring in the correct position? I just checked my hand and machine torch and there is no o-ring. I looked in the receiving parts and saw no o-ring.
The o-ring is in the connector of the plasma cutter. The large copper terminal push’s up against it to seal.
Thank you. I tried to shine back in there but could not see it. I’ll try again tomorrow with a brighter light.
If you do not have a air leak at the connector then its there.
