Prime weld cut 60 wiring questions using divided voltage
Good questions.
The CNC already had raw at CNC plug with nothing but 2 resistors in series. But some don’t like that either since it’s fed from same CNC board. Maybe I’ll use high quality resistors instead or fuses. But connected direct eliminating that CNC board.
For the fuse route, I will probably use a 2 pole fuse. But at least need one on the work clamp side.
If no one knows what the current is I will probably start with a 5a 300/600a fuse. But then put an amp clamp on it and see where it’s tracking and increase/decrease size.
I might also add 2 meter female banana jacks on the back so I don’t have wires hanging out.
Really not sure yet. Still kinda just thinking it over. I could also just add my own high quality resistor to limit current. I can’t just leave wires hanging out but don’t want issues either. So I got time to think while I wait for support to get back to me on other items
Thanks for the reply.
Think I mentioned having a hole in my machine and warranty not being an issue.
I too don’t like wires just dangling about.
Wasn’t talking about your setup. Prime sent me photos on how some do it. Shows the wires coming out of the vents. I’ve seen others like that too different plasma cutters.
I know.
The method you show there is how 99% of people do it.
Mine is permanently altered; just making the point that PrimeWeld didn’t care as I went further than the method you posted.
Joe from the group made a write-up about it; he’s in this forum as well. Just two wires to two different lugs.
Not that it helps in your case, but the plan is to go Hypertherm later down the road.
Don’t get me wrong, the PrimeWeld has served me well but it’s one of those “I didn’t know better”.
If I end up using this thing, yes absolutely. If it gets that pipe cut axis where I can do tube too. It will be a whole another ball game. This is just to get me feet wet?
Hey did you hook up red to ground clamp? Black to torch?
Yes.
Clamp (mistakenly called ground clamp) is actually positive. It’s a work clamp.
It is a clean install but so why such a large port for 2 wires? Why not have the vim installed inside the plasma cabinet and then use a small barrel connector port instead for the divide single output from the VIM? Then all the full dc voltage wires will be contained in the plasma cabinet. Just a thought I wanted to throw out there.
A few examples
Edit
Or leave the vim In the plasma Cabinet and use the factory CNC port by removing the factory divided voltage connections from the plug and then solder on the output from the Vim to then instead. No new holes. ?
A lot of ways to skin a cat.
You would need to check the ratings on those. For instance these banana plugs are rated 300v and 35 amps. Be careful what you use.
Because -
  1. I did it in haste, and when I ordered the plug I didn’t realize how big it was :rofl:
  2. I had been dealing with two issues at the same time; my VIM’s divided circuit having burned out on top of finding out my dip switch had “changed” itself because my Z axis was moving at 1/2 the increment value
I would absolutely throw the VIM inside the plasma cutter but I don’t have time for that
Did the plug idea for the simple fact that I did not want wires hanging out that could catch on something and get ripped off
I’m a welder/fabricator first (I notice many Langmuir owners never handled metal before) so I like to take my plasma cutter off table and cut stuff down for repairs as needed
there would not be 300V or 35 amp at the divide output side of the VIM.
maybe 1.5-4 volts and almost no amperage
The divider in the VIM is 73:1 I believe . so even a 500 volts on the plasma side would be 6.8 volts on the output of the VIM
Were talking about converting to use non divided voltage straight off plasma cutter. Which would go to input of VIM. Which would be 50 times higher then the divided voltage. Thats the whole idea here. Not using divided voltage. This would be the same voltage at the work clamp and torch. So you dont want to skimp.
I get the idea
You will always have a divided voltage by the time you make in through the VIM. The VIM is a voltage divider.
I am also talking about using the raw voltage from the machine.
We are talking about the same thing.
the Vim takes the 50:1 input and alters it by 1.46:1 or the RAW signal is a 73:1 divider. The output of the VIM should be 1-4V ish
Oh yeah. Gotcha. Thanks I wasn’t sure the output ratio of the VIM. :). I was still taking input. :wink: thanks.
Me too as well as also talking about the output of the VIM. The point I am ultimately making is why not just install the VIM in the plasma cabinet so no high voltage / high amperage wires are on the outside of the plasma enclosure.
I really like this idea! Thanks for posting!
Question?
How can Hypertherm make their internal 50:1 voltage divider work with no problems and Primeweld and Everlast cant? Is it product quality ? Design? why can not they make it work consistently and properly ?
How many years has this been a issue? how many versions later and still inconsistent results .
Exactly why Hypertherm is next :wink:
PrimeWeld will remain as an excellent tool for hand-torch applications.
You’ll love it. Much longer consumable run time, auto adjusting air usage, more efficient, Fan off/on on thermal load, Consumables are readily available everywhere, many of the consumables are made in the USA https://www.youtube.com/watch?v=bDnzW8Fft1k
Hypertherms they are more money up front but cheaper to run with less down time.
I have had a few different plasma cutters; thermal dynamics, miller, Everlast, no name cut50, but my Hypertherms (PM85 & 45XP) are by far my favorites
