I cant see what it would hurt but is there any reason why I cant plug my table into a switched outlet? It will be pretty tucked away when it’s in its final spot and a remote switch would be much more accessible.
Shouldn’t be a problem - of course you’d want to make sure no one hits the switch when you’re running. The USB control board seems to get it’s power from USB / PC it’s hooked to and isn’t powered off the internal DC power supply (it’s independent). The 120v plug seems to be only for the power supply that drives the stepper motors.
