Post Processeing
I could not agree more. I thought I was the only one that thought that way. I get releasing some stuff prematurely but there is a ton of stuff they just tossed out the door that looks really inadequate.
I’m finding the problem here is that the post processor skips (after the first tool) the section in post where the unit of measure is defined. No G20 results in CutControl importing all paths in metric (mm), and thus the paths do not work. Trying to decipher the post but could use some help.
I was able to modify the beginning and end within the post to include a Z up movement prior to starting and then a Z up and move to X/Y position (my tool change position). Saves a bit of time.
Dumb idea, but if the default is metric, can you just post the whole thing in metric to avoid the change?
Setting to metric fixed it for me - thanks for the idea @G_K
