So I see a lot of issues on the forums with arc voltage, cut interrupts, bad usb, noise interference etc.
Here is my question.
Most tables I have seen on the industrial scale have a dedicated ground rod for the table for noise and EMF, why wouldn’t this resolve a lot of issues people are having with the Crossfire Pro system?
I tried it once. I already had the rod in the ground near the table for other reasons but when I hooked it up I could no longer read arc voltage. I never found out why so never hooked it back up, it was more experimental then trying to fix a specific reason.
Tried this on my OG Crossfire. Didn’t help. My issues with that unit was fixed with a filter on the USB.
Still have the Ground wire laying under the PRO not hooked up.
I was having intermittent piercing problems, molten metal ending up on my shield and spraying sparks and molten metal at me, got burned a few times, but I weld and operate the table in flip flops when it’s hot so that expectedly happened.
After chasing this problem for quite a while getting bigger air lines and reducing my pressure delta, raising pierce delay, upping amperage…etc. I finally grounded my table with about $1 worth of wire and connectors and my issue has been totally solved.
Consumables are lasting 3x as long and cutting holes are perfect for what is expected from a plasma cut. It’s upped production because I don’t have to pause cuts to clear slag off the shield after piercings and is a huge weight off my shoulders. Lowered the cost of consumables 3 fold. I’m stoked!
Table is on a wood floor in a shipping container, not sure why it was needed, but onward and upward. Hope this helps someone.
I can verbally describe it pretty well for ya. So the metal shipping container is grounded with 2 ground rods and bare copper wire. I ran a piece of 12ga or 14ga copper wire (out of a wire scrap pile I have) from one of the self tappers holding the leg gussets on the table. The wire is run to another self tapper running through the wall of the container. I just used normal crimp on wire ends that fit the self tappers size. I also used copper wire dialytic grease on all connections for corrosion resistance.
If you have a cement foundation traditional shop you’d just have to run a wire from the table to the ground rods for the electrical service, or pound another rod in the ground dedicated to the table.
