Hi everyone,
I’m new here and wanted to first say hello and glad to be here, looks like a lot of knowledge in here.
I have tried to do a little searching but not sure if I’m searching correctly. I have the Crossfire Pro running the limit switches. When I load a part, it usually populates above my machine limits area. I can perform a “Set Program Origin” and get the part into the machine limits area. I can then hit manual nest to move it but it typically goes further then I’d like. My question is, is there a way to move a part within the machine limits area to a specific spot?
Are you choosing the spot you want it to cut and zeroing your x and y axis?
Move the torch to the point you want the point of origin to be and zero your axis.
Welcome to the forum!
FYI, I’ve moved your post to the CrossFire Pro category just because… ![]()
Thanks.
TOMWS edit: Not a problem! You’re welcome. I look forward to your participation.
I will try that and see if that works for me.
That is definitely your issue if you’re are not doing that …
Hats off to you for finding a work around.
That definitely was the fix. Thanks!
Awesome share some pictures of your work w love them.
The forum has a whole section for projects.
