Hello Everyone,
Every time I tell my machine to make a cut I get this error:
A plasma cutter misfire was detected by the LS-THC system. Your program has been paused and the machine location has been saved. We recommend clicking ‘RETRY CUT’ below to try this cut again. If your plasma cutter is misfiring frequently, we suggest replacing the consumables. If your plasma cutter did fire before the cut was stopped, the cause for this issue is that the pierce delay in your program is too long. As a result, the torch burned out the pierce hole and extinguished before it had a chance to move. We recommend selecting ‘RETRY CUT’ and using the Pierce Delay Override to decrease your pierce delay.
The cutter does fire before the cut was stopped.
Now if I hit ‘Retry Cut’ it cuts no problem.
Plasma Cutter: RazorWeld RazorCut 45
What I am cutting:
- .25 mild steel
Settings:
- 1s delay all the way down to .05 delay. Nothing changes
- Amps: 45
- IPM: 50
- Cut Height: .06
- Pierce Height .15
- Kerf: .045
- Plunge 6 IPM
What I have tried:
- Tested my THC control and it appears to be working fine.
- Reduced delay down to .05
- cleaned ground
- new consumables
No dice with any of these fixes.
Can anyone help with this?
Thanks
Brian
