Pausing During 2d Adaptive
I was running my machine yesterday and the machine started randomly pausing mid cut. It happened ~ 10 times, and each time, it would just sit there for 2-10 seconds, then pick back up where it left off like nothing happened. As far as I can tell, no skipped steps, part came out just fine and dimensionally accurate. Anyone have any thoughts on how to fix this? It didn’t cause and issue on the part I was making, but I am concerned it could cause issues in the future.
A bit more info:
1/4” 3 Flute Carbide end mill. 0.100” optimal load. ~0.4” depth of cut. 45 IPM. Machine sounded great…didn’t seem like it was pushing it hard at all.
Issue only seemed to happen on 2D Adaptive cuts. Never on any of the Contour or Pockets (Fusion CAM).
I ran two relatively similar parts (.f3d files are attached). Both had 2d Adaptives, but it only happened on the second of the two parts. Seemingly the only difference between the two is that I have “both ways” (Climb and Conventional) selected in the toolpath that was experiencing the pausing issues.
The pausing seemed like it was “buffering,” like you would experience with a youtube video. Could it be a failing USB connection?
Left Side Plate.f3d (417.8 KB)
Right Side Plate.f3d (280.0 KB)
How does it run in simulation? Of it pauses there its the program if it doesnt it could be the program or the machine.
Yeah I’m not getting any pauses in the simulation. The pauses seemed to be way too random to be a program artifact…not only are they at random spots in the adaptive cut, they were also random lengths of time. One of my 3d printers experienced something similar a while back where the interpolated curves were somehow creating a data overload issue causing the printer to error out. I’m a mechanical guy though so the computer stuff is beyond me…
I’ve seen this a few times over the years with my machine. No skipped steps and it will just pause for sometimes a second or two and then goes back to running.
The times I can think of that it has happened has been during both 2D and 3D adaptive cutting. The g code is clean where it would pause but, like you said, its like the machine buffered for a second and then went back to running. I’ve seen similar things on more industrial machines where it’s like the control, or pc in this case, doesn’t register that the previous move has ended. Possible momentary loss of connection, but not enough to cause an alarm.
Had that happen last week on one of our VTLs with live tooling. The program has been proven out for a year or so, but one day it just dwelled for about 5 seconds before threading a hole on the part.
Do either of you have your machine connected to the internet or have other programs loaded on the computer, assuming that its the computer langmuir supplied with it (the mini one). Im wondering if it could be malware or just to much stuff going on in the background. I do not nor will mone ever be connected to the net and it only runs cut control. Its the langmuir mini pc
No internet connectio. And nothing other than cut control and basic windows apps on the pc
Yeah, I use USB for file transfers and I only use the PC for cutcontrol
I’ve had an occasional pause from time to time, but any time I do, I reset my pc and start again and don’t have any issues.
I’ve never noticed a difference in how I get my program to cut-control. Once its in there, it’s there and just standard G-code. No dwells or anything. It’s always been a pc restart every time for me.
Well…I’m back again on this topic. The pauses are bad enough to where I’m worried it will screw up a part. I ran a dry cycle last night with no tool just to check some clearances and it would go for MAYBE 30 sec before pausing. Each time, it would pause anywhere from 1-10 sec before picking back up. I’m not much of a computer guy, but this feels like it is something along that line (maybe a USB cable going bad? Restarting the computer hasn’t seemed to help). Any suggestions on what steps I could take to diagnose this issue would be greatly appreciated!
Do you have any other equipment running that is near or touching the mr1? I have a shapeoko 3xl and the data cable was touching my vacuum hose, when the vac was running static would build up and cut out my connection from my laptop to the controller board. That could be a similar issue, also id try a different cable to be safe.
Nothing running nearby unless you count the coolant pump
Can you post a video of the computer screen with the gcode window open when its running so we can see whats going on when it pauses? Prolly gonna have to post it to youtube and send us a link.
Yeah I’ll do that tonight
100% of the pauses Ive experienced have been the result of the windows antimalware executable hogging all of my computers resources. It is one of the most insidious peices of windows software I’ve ever experienced. It has several layers self preservation that need to be either removed or disabled to make it quit.
My Langmuir mini-pc died after 3 years so I replaced it with a mini industrial and both the Langmuir and the new one took way too long without a keyboard to get it disabled.
Windows uodate can be another one but if you’re not networked with internet access you shoukd be good on that front.
Yeah I’m not connected to the internet so it shouldn’t be trying to install/download updates. I’ll look into the Antimalware software idea. Unfortunately life caught up to me this last week so It’ll probably be a month before I get around to it :zany_face:. Good thing it’s a hobby machine and not critical.
