After finding starting point on material with touch probe and setting end mill with tool setter I start program and mill is running process exactly 1 inch above material .
Most likely are getting the steps out of order. After probing the x,y and z you make sure in tool setter it is set to probe than hit calibrated. This will move to touch the setter with the probe. Than switch tot he end mill of choice than use the “white button” “auto tool set”.
Yep that was it missed that in the instructions . Thanks
