Hi, my UPS tracking is saying my table will be here tomorrow, Crossfire Pro with the THC. I am located in Langley BC, just outside of Vancouver
Excited to get it up up and running. I work with SolidWorks and program CNC machines as part of my day work, and picked up SheetCam for posting to the Crossfire Pro.
I am sure I will have some questions once I start assembling… currently just watching videos on the machine and reading everything I can here.
whaich table do you have and when did you purchase it? if really new, then you gotta use firecontrol… If over a year old 2x2 crossfire then it uses mach3.
Slowly getting it assembled. Been super busy with work. I welded the water table up and have started making a base for it with a shelf and caster, plus a steady rest for larger sheets.
When I did mine…
I bolted the two sides together…no adhesives or glue…cleaned the flanges well
fastened them to the table as instructions indicate…
put about 1/4" of water in each pan…
TIG melted/fused the seams between the flange bolts…then removed the flange bolts and finished welding it…
filled it with water and ran a high pressure air gun along the underside of the seam to check for air bubbles…
had to touch up a couple of points…but other than that…
zero warpage…zero leaks
I was doing a couple of practice runs on some scrap stainless I was able to mock up to simulate the weld. Looks like I will have to notch out the bolt holes some from a “U” to more of a “V”. Do you see any drawbacks to that?
