Hey any inputs on this nesting? It’s understood we need to look at lead in to insure we don’t pierce adjoining parts. Is 3/16’ a good gap for manual nesting adjacent parts on 1/4"stock. We did some initial tests and the remnant ribs warp but they are scrap anyway . K
How much of a lead in and out are you doing? I nest parts out on 1/4 plate about 3/16 or .180 . My parts have a good radius in the corners so that gives me plenty room for leads.
Not sure I think when I run the sheet cam tool it will show me if I am piercing where I don’t want to . Haven’t applied the cut tool yet. maxed at my other job.
I would look at like this. If you leave a 1/4 between and have no problems or scrapped parts you will feel much better than if you leave 3/16 and have the opposite. my 2 cents
Thanks we will run this nest space gap at 1/4 gaps to start . Thanks for inputs we still haven’t loaded a sheet cam cut tool for HT 65 Sync. for 1/4" mild steel so you can tell we are newbies.
Yes Sheetcam manual nest. Get one of each part in and apply your tool set and get start points and lead ins dialed in the way you want 1st then duplicate parts.
Working on some splash guards when running these full sheets. Probably start a new thread as it may be in depth & relating to avoiding splash into the Z axis as well. Potential redesign or additions to the existing plastic guard. Keep safe and get onto those tasks!
Some interesting skeleton bits. With some cut off wheel work we see some cool common shapes usable for weld art. Interesting thought to imply when nesting.
