need to slow down
need to slow down between cuts so i can pause it to remove tip ups
Welcome to The forum
We can see that you have less than 1 minute of read time on this forum.
There is quite a bit of information about this topic.
On the top right hand corner there is a magnifying icon which is used for searching content of this forum.
https://forum.langmuirsystems.com/search?context=topic&context_id=43024&q=Pause%20order%3Alatest&skip_context=true
You could further refine this search by adding in which type of post-processing program you’re using.
In fire control you can use spacebar to pause or manually hit the pause button during a rapid between cuts.
