Hello Everyone,
I’m just starting my MR1 build… considering a few modifications and thought I’d share for feedback.
The first mod would be a ballscrew upgrade with double ball nuts to help eliminate any backlash… Initially I was only considering this for the X and Y axis, but then after disassembling the X/Z carriage I couldn’t help but notice the contrast between the heft of the impressive cast iron carriage and the tiny Z axis acme leadscrew. A larger ballscrew would seem to be a better match for rest of the machine (though I understand the reasoning for the acme leadscrew with the challenge of shaving costs everywhere possible to keep the price of the MR1 as low as possible, while maintaining impressive performance).
A couple questions:
How much improvement in chatter reduction and surface finish do you think could result from reducing backlash compared to the stock setup?
In order to use the stock electronics and CutControl, the upgrade ballscrew pitch would have to be a multiple of the stock pitch (for adjusting the pulses/revolution setting on the stepper driver). That’s not a problem for the X and Y axis (5mm pitch), but the stock Z axis pitch is 3mm – which is common for ACME leadscrews but not for larger diameter double ball nut ballscrews, as far as I understand. I was thinking of using a readily available 5mm pitch ballscrew for the Z axis. Are there any options in CutControl for changing the ballscrew pitch the way you can in DIY controllers such as Mach 3? Am I missing something or does this make sense?
Thanks for any feedback.
