I didn’t want to short anything out, electricity isn’t my forte.
But I wired 1 as positive and it works thus far through cut control
Its just a simple switch relay
Can’t recall how I wired mine, but a quick check with the multimeter will tell you. Manually enable the coolant toggle in CutControl.
Just email Langmuir and get the answer. I used their supplied harness. Not worth finding out you burned up a control board. Just my two cents.
As long as its a standard relay it wont care, coils can be energized in either direction. If you don’t have a multimeter you can just open the enclosure box up and trace to ground.
