Getting ready to pour concrete and after looking at a few pictures from the ongoing builds I have yet to really know how much distance I need to pull the base off the wall for cords. I figure the back wall will go straight up from the pan but can also see some extra supports on a few pictures that may protrude further. Can anyone tell me a safe distance to come off the wall to allow all those cords to run down the back? I tried looking closer at all the pictures but just couldn’t tell. Thank you.
That looks like you might be having fun to put the surround on
I epoxied the nuts on the underside before I started. So I can do everything from the top. I was going to weld them on but didn’t want to repaint or warp the surface.
Great, thank you for the info. I will plan for 2.5 inches to be safe. Cant wait to get it going.
So thread inserts would be a good idea for people wanting to put it close to walls.
I am also planning to be tight to the wall … after reading all these threads I need to compose a list of stuff to remember and watch out for!
Are you thinking like rivnuts? If so you’ll create a gap so you’d need to gasket the enclosure on the base flange or use extra silicone.
