So not an issue.
For post flow my main concern was start the cut then having to wait till post flow finished before being able to fire for the next cut which would be terrible. Luckily the way it work is if you cut out a section once it stops cutting postflow happens but if it needs to fire it will stop post flow and fire. Only at the very end of your last cut will postflow actually stay on for the 20sec. What I would like to do is have it move back to Zero after the last cut instead of staying at the end of the cut but not sure how to do that.
I did my 1st test cuts yesterday. The came out beveled and horrible. I put my welding helmet on and got close noticed the plasma angle was weird. Turns out to be bad consumables. Heres what I noticed after troubleshooting for a few hours.
-1/8th mild steel go slow. Im going at 20in/min even though the manual says 40 (which is suppose to be only 80% of max… unless i’m misreading this manual)
-30amp setting
-at least .2inch for lead in or you risk blowing your edge
I guesstimated kerf (if you happen to know this let me know)
Let me know how your 375 is working ! Good luck!
