The Work Clamp is on the work piece, however I have tried multiple locations. Including drain plug, slats, water tray.
.6 seconds should be plenty long.
perfect . good choice.
failed once again.
Can you straight line cut without the THC active?
are you running from PV output on your VIM to the Langmuir electronic enclosure?
Yes Sir. That is the way I plugged it in.
EDIT> I just ran with THC off and it succesfully ran.
