If I build stands to hold a full sheet of 4x8 steel. Will I be able to cut a full pattern out of a 4x8 sheet by feeding it through the Cross Fire Pro? I realize I will have to stop the machine then start again as I go but just curious incase I need to cut a larger design if this is possible? Thank for you time and hopefully this made sense…LOL
Yes, you can. Check out the Arclight Dynamics video on “indexing” to see how the process works from a software standpoint.
Thanks!
Scott
