@Phillipw The marking consumables for the Hypertherm 45 Sync is the Fine Cut Cartridge which is the one I am using. Which brings up a good point because the whole exercise is to learn how all this stuff works together. In the future I want to build a 2 x 48 Belt grinder like @ds690 did.
So all that all being said, I may have to change consumables between the marking and the cutting operations. But with the pro tip from @Craig1 on inserting the Code Snippet between the drilling and cutting operations, there will be plenty of time. I tried it today and it works just as he described.
Thank You Guys for all the Pro Tips
Tim
