I am about to order an “update” torch for an older Hypertherm Powermax 600.
The machine torch is a couple hundred more than the manual torch……
Is it worth it?
Are there any major draw backs to the manual torch?
I like the idea of maintaining the ability to use the torch manually. This machine will be in a Makerspace and not everyone who does metal work will want to learn how to use a CNC machine. I was thinking of keeping the old torch with the “inferior” and hard to find consumables. The torches have a panel mount cannon plug so it would be easy to swap them out, I think.
How much hassle is it to remove the torch from the Z for manual use?
How many people use their plasma manually after setting up a CNC table?
The machine torch is neater. The torch cable is out of the way there is less leverage on the z axis in my opinion. The consumables can be changed without taking the torch off the machine.
The bad side is you can’t hand cut with a machine torch. It is definitely a advantage to have both.
You will likely need to buy a different mounting bracket for the z-axis. If you try to clamp down on the end of the machine torch with the hand torch mounting bracket, you would damage the consumables and possibly the torch. I am not familiar with what you call:
The machine torch will not be able to be used manually. It does not have a trigger and would be unwieldy.
I really like the machine torch set up but if you want one to do both, you would not like the machine torch.
