LS Cylinder heads
My machine is dialed in pretty good. Do any of you think I can successfully resurface a set of Chevy LS heads? My friends kid is trying to rebuild a C10 and has an extra set to try. He’s hell bent on wanting to try it on the MR-1 lol.
I am not sure that an LS head would fit.
I have done them on my Bridgeport with success. Let us know how you make out. I believe that the height and the length may be out of the operation window.
I surfaced a set of Brad Anderson Hemi heads on mine after the decks were welded up so LS heads shouldn’t be an issue
Someone on here made some LS valve covers I think so I would assume they would fit. I think I checked it once out of curiosity and it was a close fit but doable. The work holding was the big kicker.
