Lotos LTP5000D Plasma Cutter
I checked that my consumables are seated properly and to my surprise the cup was not on tightly, so that has been fixed and everything is now seated in place, However I am still in “torch protection mode”
I found your original wiring notes Tom, looks like my torch has all the correct pins in place, except for pins 3 and 5 which don’t seem to be needed with this torch. Previously I mentioned that my torch is an x45 style but the actual model is “iptm-60” (not sure if that’s worth mentioning) which shouldn’t matter as long as the pins are correct I’m assuming, which they are based on your notes, so I am at a loss
I can help you with this. If you want to PM me.
I don’t believe I can, I’m too new here, but any help is greatly appreciated
I sent you a PM.
Talked to @Dehaas22 today about his torch. It was wired correct and it seem like the plasma cutter has a bad PC board because everything checked out fine other wise. told him to contact Lotos and see if they can do anything for him.
