Hope you guys can help. I’ve been trying to do my research on this and now I need help.
I am getting 5.0v live voltage when the plasma is not turned on. If I removed plasma work clamp off table it reads 0.0v
I have a USB voltage isolator and multiple to each motor, plasma and a ground rod connected to the table w/2ga wire. Control box is not connected to the table and removed ground pins on a/c plugs.
Here is my setup.
Crossfire Pro
Everlast 62i CNC (THC connected via RAW voltage)
Mini PC 8gb ram
Asus Touch screen monitor
Thanks for any advise. Alfie
