Laptop don't have enough HP, need assistance
I have a file that is to much for my laptop to post process. I don’t know is there a way i can get some help from someone were I can send it to them have it post processed and able to revive back a NC file that I can cut? I’m sure I can make it worth a guys time , it just crashes my computer . I actually lost the job I have to send the sheet back to the guy in canada in the morning but I’d still like to cut this and get it to him out of lower grad steel I guess.. cmmagnus3@gmail.com is my email Timber Tiger Forge on social media. Business profile on Google has my phone number and all that stuff. Don’t really need any replies on hear I just get chews up for spelling and not posting correctly. If you think it’s worth your time just shoot me a message or call, thanks everyone the forums hear are nothing short of amazing and very glad to be apart of the community . Chris Magnus Timber Tiger Forge . Ok specs or info using fusion Crossfire pro. Just initial hight no torch hight controller. Razor weld cutter with a x45 torch the one with the flame on the side . Just cutting out of 1/16th or 3/32 steel. 3hp 100 gallon compressor , commercial air dryer , marlin large decant ,container couple water traps a motor guard filter setup directly on the back of the plasma power box cuts pretty dry for the most part only run about 35 amps most of the time. The cut project is for a YouTuber who reviews kitchen knifes . Thanks agin
buy sheetcam it will process any DXF or SVG file into gcode for the tables….I yet to find a file it can not do in seconds.
I did a part that had over 2000 pierces and had to be on the table for 45 minutes of cutting time…….it was processed in 6 seconds……
Post your f3d file let’s see what you have going on.
A lot of the time if you reduce your tolerance by one magnitude and add smoothing in the 2D profile menu it will really help.
