Hello, I just ordered the Pro today.
I currently have a normal crossfire with XL kit.
After steep learning curve, I have outgrown it.
Time to search here for caster ideas, and drain mods.
Congratulations. You won’t look back.
I have casters on the bottom of my legs. I welded a plate on the bottom of each leg. They are very secure.
Foot Master GDR-60-F-NYN Leveling Caster, 50 mm Nylon 66 Wheel, Iconic Ivory, Height Adjustable Ratchet, Plate Mounted Swivel Caster, 250 kg Load Rating https://a.co/d/honPKmw
You must be very careful not to rack the legs when moving. Many are finding that is preferable to make a wheeled base that the table sits on.
I did not do any drain modifications but knowing what I do now, I might have created a draining/filtering/refill system. You can always do that later.
