Jog Controller for CFP?
Does anyone know if this controller would work with the CFP?
https://www.etsy.com/listing/1466965513/jog-control-for-shapeoko-carbide-motion?click_key=4861816035c04675c906f527e5a29ab3644f6e10%3A1466965513&click_sum=6f6fe67f&ref=ucl_sl_si-10&frs=1&sts=1&fbclid=IwAR1JB9XTMFiDpMQsf5sb1YFHOnfyNtVaoR_IjAI5A20BnTR_MfX1-tVeDy8
Reading the instructions it looks like its just mimicking/extending the keyboard functions used to jog.
The keypad buttons send the following commands as keystrokes detected by the Carbide Motion software:
Y + (moves in positive direction on Y axis)
Y - (moves in negative direction on Y axis)
X + (moves in positive direction on X axis)
X - (moves in negative direction on X axis)
Z + (moves in positive direction on Z axis)
Z - (moves in negative direction on Z axis)
1 (Sets jog speed to lowest speed: .025 mm or .001 in depending on ‘units’ setting)
2 (Sets jog speed to second speed: .25 mm or .01 in depending on ‘units’ setting)
3 (Sets jog speed to third speed: 1 mm or .1 in depending on ‘units’ setting)
Fast (Sets jog speed to fastest available speed)
If it doesn’t require a driver and it sounds like it may be compatible with any keyboard…
There’s a very good chance it will work.
This works like a charm. Been using it for years.
havit Bluetooth Number Pad Wireless Numeric Keypad Numpad 26 Keys Portable Mini Financial Accounting Rechargeable Numeric Pad for Laptop Desktop, PC, Surface Pro,Notebook (Black) Amazon.com
Rii X8 Mini Keyboard,2.4GHz Portable Wireless Keyboard with Touchpad Mouse,RGB Backlit,Rechargeable Battery for Android TV Box/Mac/PC/Nvidia Shield https://a.co/d/diQqIVU
This works great too. I prefer the Numeric keyboard. Less button to deal with.
which keys work for the zed axis?
Page up , page down. All the arrow keys work as expected. Battery life is fantastic.
Like a year on a AA lithium.
Note: your computer must have Bluetooth
obviously.
Is there some advantage over using an X-Box controller and Antimicro driver? They are under $20. I use a wireless one and a wireless keyboard. Either works fine and both can be had for a total less than the one linked.
