I give up on Fireshare, so here are the files for the magnetic drill press fence.
Fence DXF stats: 16" long, 1/4" thick steel, plasma holes are intentionally undersized, you need to drill them with 5/16" bit and thread with a 3/8"-16 tap.
Requires 2 Magswitch 150 switchable magnets: https://www.amazon.com/Magswitch-MagJig-150-Set-2/dp/B01B59KW6Q/ref=sr_1_4?crid=2O28Q0M63X8D8&keywords=magswitch+150&qid=1687185590&sprefix=magswitch+150%2Caps%2C109&sr=8-4
STL included for 3D printing the mag mounts. Magnets are a perfect press fit for me (CC3D Matte Black PLA on Bambu Lab X1C, your setup may alter the print accuracy so size up a fraction of a percent in X and Y axes only if necessary.)
Need 2x 3/8"-16 hex bolts with 1 inch thread. Bolts may need to be ground down and shortened the smallest amount if they extend further out the front holes.
DXF for plasma
drill press fence v1.zip (9.7 KB)
STL for 3D prints
magfence mounts centered.zip (5.5 MB)
For reference to post above:
