Issues facing the baseplate
While facing the plate I am getting a “machine has been disconnected while executing programming execution operation” this is my second time running the operation and it did this both times it gets about 90% done and stops
FYI I am using cut control V24.1.1
Replaced the USB cable and now it seems to be working better
Did you have to install any upgraded stepper drivers or anything like that? When I did mine, I bumped a connector or two, so I went through and made sure everything was seated well. I found a few that I probably disturbed that needed to be seated. I know this is kind of the “Indian Call Center” type of advice, but it wouldnt suprise me if you have a connector or two loose.
I did install the upgraded drivers. It seems as if it didn’t like either the length of the usb extender OR the usb hub I replaced that switch a single usb cable (active) and it seems to work.
