Guys I’m pretty useless in electronics. Is there anyone that can make a cable for an Everlast Plasma cutter and the Crossfire Pro table? I just can’t do it. Be happy to pay!
Didn’t some people confirm that the Eastwood cable works with the same plug and pinout?
Thing is, you’ll still want to run RAW voltage if you opted for THC as many people experience issues with a resistor blowing out in their VIM.
This means, you’ll only be using the plug for just two wires which are torch ON/OFF.
On the plus side, this means you’ll only have to solder 2 wires instead of 4 to the plug.
The remaining 2 for RAW can be terminated with some ring terminals and bolted onto the lugs for your work clamp and torch. Lots of pictures floating on how to tap into RAW for an Everlast.
Thank you,
