Hello everyone
I just want to say hello to all the members. I hope to share my experiences with you.
Thank you,so much
@robbie12 look forward to seeing what you do. Welcome to The forum
Welcome to the forum!
You put your original message under the Crossfire Pro so I assume you have purchased or plan to purchase the Pro. What cutter do you plan to use and what do you envision will be your primary projects for this wonderful tool?
Thank yo so much!!
Hi, I am new to this forum, and I am considering buying the Crossfire Pro. I was wondering how close it will cut 14Ga. Mateial. Does anyone have experience with this machine? I have a Hypertherm XP45 for a cutter. I am hoping to hold about .015 tolerance because I am planning on cutting and bending sheet metal. Any feedback would be most appreciated. Thanks
over what kind of distance?
It does sound like your minimum tolerance is going to be the pros maximum tolerance when plasma cutting.
Not saying it can’t be done but it’s quite easy to lose a 64th while plasma cutting
Probably over about 10.0 to 12.0 inches
