Interesting results using Fusion360 simulation and NCViewer
All,
Full-Leg v4.f3d (167.1 KB)
Full-Leg-Test.nc (24.2 KB)
I need someone more experienced than I to help me figure out why this model doesn’t seem to want to simulate in NCViewer. I use Fusion 360, and when I do the CAM setup and run the simulation, the simulation runs. I also tried the .nc file in NCViewer and it doesn’t cut the holes and some of the outline. The odd thing (at least to me) is that it extrudes without issue within Fusion 360 and that makes me assume all of the lines are connected.
Any insights or tips would be appreciated.
Disregard!
The body selected in the Setup is no longer valid for whatever reason. Perhaps you edited the sketch after you created the body and the reference was not changed.
Select the bodies for Setup as your “model”
Now edit the tool path as the same thing was true (missing reference):
Select the bodies:
Click Okay
Full-Leg v4Chelan.f3d (188.7 KB)
Run the post processor again and this should work.
Thanks ChelanJim! Running that now.
