Does anyone know where I can get the insulated male & female connections that plug on to the switch?
There was an incident when trying to manage the cables.
I’m assuming you are talking about the dreaded limit switches. uxcell 100pcs 2.8mm Quick Splice Wire Terminals Female Spade Crimp Connector with Insulated Sleeve Amazon.com
uxcell 100pcs 2.8mm Wire Terminals Connector Quick Splice Male Spade Connect with Insulating Sleeve Amazon.com
Langmuir will help you. But here they are 100 count.
Any insulated connectors will work. It’s only 5 vdc.
That’s what I was looking for. Thank you!
