thanks so much.
this is what it looks like, not to much difference.
when i take it to inkscape do i need to trace bitmap it?
i tried and nothing happened.
i got it to bitmap, operator error!
if i take it to fusion what would i need to do from there? is it a detailed process?
You should be able to save that SVG at the size you need in Inkscape and then use Convertio to convert if to a DXF. I’ve found that converting to DXF with Convertio produces a better result than “trace bitmap” in Inkscape.
post your original file and I few of us can take a crack at different methods.
My workflow would be much like this in video 5. besides whatever repair or modification the file requires .
I almost never use inkscape anymore .
Convertio.co algorithms seems to be improving exponentially.
I’ve been really impressed with the results on some fairly complicated images.
ETA the SVG didn’t load!
this is where i got to, i had to walk away cause i was confused!
I think i have it traced in the red with the black JPEG next to it.
I need to add it to the center of the 12x12 cross
I still have some things to fix.
Could you post your original image file not the SVG.
please
Thanks, I would need to remove the inner line on the letters so it would be solid cut out.
this one is slightly cleaner
yes definitively more work to finish this design
I would be in Fusion 360 after converti.co so…
Any Inkscape guys out there to carry this one on?
i will work on it some more thank you for your help.
that looks clean
yea! thanks. i just have to figure out how to fill it with black! hahahahah
I’ll get!
