I have been using inkscape and sheetcam together since Sept of ‘25 with no issues. However yesterday, I have 3 files that will not open/showup on sheetcam. I can open files I made before these and files I’ve made after. I’ve closed both applications, multiple times, I have restarted my PC. I confirmed they are in the correct format of SVG. I’m at a loss here. Any help would be greatly appreciated.
This will show a new window on the side called ‘Layers’. You should see a layer for each color or layer type listed. If any of those are unchecked, Check them and you will see them appear in your job. If they are unchecked, they won’t be processed.
I don’t know what’s going on with that file, but I can’t make it work in Sheetcam. I even tried making a bitmap copy and tracing it and it still shows blank. I tried to create an operation and there is no layer.
The attached file won’t open in sheet cam for me, it opens as a part without layers. But if I open it in Inkscape, then export it as a plan SVG, it works just fine in sheet cam. My guess is when you exported it the first time you did something different.
Sorry, I mean the one @DNWGrunt attached to his post. That won’t open in sheet cam as we all saw. But, opening it in Inkscape, then doing nothing other than just exporting it as an SVG, then putting that in sheetcam, works perfectly.
I know you are not using F360, but just to let you know the SVG loaded into F360, Extruded, and Manufacturing generated a Tool Path without a problem. So, apparently the SVG wasn’t(isn’t) causing the issue your fighting.
