I dont think so, I will check when I can
@Phillipw, adjusted ipm to 65, still not completing the part. Torch does not raise up before the issue of not cutting…I do not know what else to do
ok, I do not know why…but my machine does not like a nice, clean area for the work clamp. I put it on another unclean spot on the steel and I have successfully cut out 2 complete F-Bombs.
Maybe something wrong with ground clamp? Loose connection?
Was also going to ask if you had tried different files.
I have no clue…it is working so far…knock on my head (hollow wood)…lol
1st successful non-test part with new air setup…
@TinWhisperer @nicaDd @Phillipw @mechanic416
@toolboy
Thank each and every one of you for your help, it is greatly appreciated
Looks good, your on your way.
Sweet success
You need to look at cable connection on work clamp, lose connection between cable and where it attaches to the clamp. The cleaner the surface for clamp the better period…
Or you were not clamped to your material directly?
I was clamped correctly on a freshly cleaned surface. Once I move the clamp to another location that was not cleaned, everything worked as it should.
I did check the cable to see if it was loose, it was fine.
