I didn’t see if you’re using drag tips so your pierce & cut height are where I’d start. For pierce height I would go to 0.15" as generally recommended. Then on the cut side I’d use the recommended 0.06" height.
If you have THC with thinner materials that may be experiencing spring back, then reducing the cut height by 0.01-0.02 might make sense but start with 0.06 and then fine tune.
DDCW
March 28, 2022, 11:04pm
22
I am done for the evening. I will give it another go tomorrow.
Thank you @mechanic416 @nicaDd @TinWhisperer for commenting and trying to help me out.
ds690
March 29, 2022, 12:43pm
24
That pierce height is way too high and the cut height is too low. As mentioned, start with .15 pierce height and .06 cut height and see what that does for you.
DDCW
March 29, 2022, 9:44pm
25
ok everyone, I am back at it.
Changed to recommended settings and still not completing a part
@ds690 @TinWhisperer @jamesdhatch @mechanic416 @nicaDd
DDCW
March 29, 2022, 10:53pm
26
I swear this thing cut parts BEFORE I upgraded air with copper pipe and refrigerated dryer
makes me think you are not getting proper air flow …do oyu have a pressure gauge on the plasma to watch your air pressure?
DDCW
March 29, 2022, 11:58pm
28
I keep an eye on the gauge on the front of the plasma…it reads 75-80
DDCW
March 30, 2022, 5:15pm
30
@Phillipw , yes as it is cutting
I may not have seen when I read through what plasma torch do you have?
Have you tried slowing ipm. I have the razorweld also. When I get home I can look to see speed… I normal cut 14 ga at 90 ipm.
DDCW
March 30, 2022, 7:01pm
34
the cuts on 11 ga at 85 ipm and 45 amps looks great, its just not completing the part
I would try about 65 ipm for a go. Where are you getting consumables and have you tried new ones
DDCW
March 30, 2022, 7:06pm
36
I have hypertherm consumables right now, gonna use them up and then get the razorweld. And yes, I have put new ones in…
Here is a cut chart. There is a guy on here sell the best ones I have used . Name is George.
DDCW
March 30, 2022, 7:08pm
39
I will not be able to work with table tonight…but tomorrow evening I will adjust ipm and see if that cures things
It may I hope. good luck hope something will help.
One more ?? Is your torch raising before it stops cutting?
